tranmx2 wrote:P0642 low voltage singnal - check the connector to the EGR. Is the harness part of the connector fully fitted onto the EGR connector? Look for a bent male bin - a loose fitting female. Check wiring at the connector for damage. Dirt.
Check wiring / con's disturbed by the change esp the cam sensor and rail pressure sensor.
