P068a
P068a
Postby tompe » Thu Apr 17, 2025 9:34 pm
Hi all well my mk7 2011 transit has the P068a fault code pcm power relay de energized too early .I've changed battery glow plugs back of the key on the barral cleaned cleaned intake manifold egr .when it starts it's sweet but getting it to start a right pig is there anything else I can do to fix this please help
tompe
Re: P068a
Postby knobby1 » Thu Apr 17, 2025 9:52 pm
tompe wrote:Hi all well my mk7 2011 transit has the P068a fault code pcm power relay de energized too early .I've changed battery glow plugs back of the key on the barral cleaned cleaned intake manifold egr .when it starts it's sweet but getting it to start a right pig is there anything else I can do to fix this please help
Suspect PCM/ignition relay issue...also check all aerths...especially the earths under the PCM on the left inner wing.
Re: P068a
Postby tompe » Thu Apr 17, 2025 9:59 pm
Hi thanks will give that a go tomorrow should said change relays aswell
tompe
Re: P068a
Postby tompe » Fri Apr 18, 2025 4:46 pm
Cleaned all earth straps still messing around ive noticed that the feul pump is getting very hot after engine is off while running seem ok but to hot to touch when off is this the a failing pump
tompe
Users browsing this forum: MinorMatt
