Because of the mounting of the new chain I had everything easily accessible I thought to start today with replacing the right front wishbone. As expected the rear bolt is stuck. I have, as can be seen in the picture, ground out the wishbone as well as the rubber. However I still can't get the bolt loose with 580 NM (427 lbft) torque power. A midsize breaker bar doesn't work either. What is the best next step: heat on the inner sleeve of the rubber casing where the bolt is in, or try to carefully grind out this inner sleeve because it also causes friction. Or is it only the rusty bolt at the top in the length frame member that prevents the bolt from coming loose? Suggestions please! The new bolt is available ready to be fit with the new crossmember. Heat, longer braker bar or higher power torque machine?
Update; I have ordered a 1600 NM (1180 lbft) lectrical Makita torque machine now. Let see what happens tomorow.
