2010 - 2.4 - lwb 100/350
Been doing a lot of work on it and converting to a camper over the last 8 months, thought it was ready for the Mot
Failed on leaf spring cracked , right above the bolt, would never have seen that ….
And also on front passenger side lower suspension arm and an advisory on the driver’s side one + a leaking half shaft gasket…
Ordered 2 new leaf springs and wishbones + gasket,oil seal and nut for the half shafts…
Thought I would spray all the bolts and see if I could loosen them ready for next weekend,
Al came loose apart from one , passenger side rear wishbone bolt… hopefully if I keep soaking it in penetrating fluid it may come loose…
But knowing my luck it won’t
Is it best to cut the wishbone off to get to the bolt sleeve to apply some heat…
I only have a plumbers type blowtorch will this be able to get enough heat too it… I do have a powerful makita rattle gun to help out…
Where can I get a replacement bolt from…
Any advice welcome
Regards
Parky
