Evening all,
Just need some clarification. It turns out that I have an intermittent issue with my reverse lights. First port of call is to replace the reverse switch. I’ve done some research but get conflicting results. Some say its on the side or back of the gearbox, others say its a white box type thing by the selector cables on the top. I’ve found neither but there is a sensor on the top which I’m assuming it is:-
Would this be it?
Cheers all.
