tompe wrote:Hi all mk7 2.2 2011 had the P068a code now sorted but no3 cylinder is feuling at 2.23 down to 1.98all other are negative is this how it should be thanks in advance
Ideally they should all be zero....but this never happens. If you add all results together they should all be close to zero.
Have you reset the PRV open/duration timers..?? Have you performed the pump, pilot & injector learns..??
Results of +/- 1.0 are acceptable-ish. After the learns they should be a lot closer to zero if the injectors are in reasonble condition..
