Hi, some time ago I replaced the pump in my mk6, coded it in with forscan. There are no DTCs so its not an immo issue.
Before old pump died completely, it would intermittently start, when it felt like it, and run for a few days then back to P1664 etc.
I thought, possibly the timing chain had slipped, but today I finally got around to taking the timing cover off. Timing seems to be OK.
Doesn't even sound like its trying to fire at all. Bloody thing is driving me mad now. I'm at the point where I'm feeling like throwing the towel in with this engine and either swap it, or put the box on a hopefully more reliable mk7 chassis.
Diesel is being delivered to the injectors, no leaks in fuel system as far as I can tell. I haven't taken the rocker cover off to inspect under there, but presumably if timing is good, I shouldn't need to?
Anyone have any ideas? I'll post pics of how timing sprockets look with flywheel locked if anyone wants to take a look for me?
If its not timing and not the pump because its a new pump, what else would stop it starting?
