Hi I'm back again, soo the van still will not start on its own steam as previously listed it's had
PRV
SCV
FUEL FILTER HOUSING & FUEL FILTER
RECON INJECTORS
GLOW PLUGS
ALL LEARNS COMPLETED SUCCESSFULLY
NEW IGNITION SWITCH
I've about given up now, I think it's time to drop it at a transit specialist, I think it's air in fuel related, will run on carb cleaner but as soon as it's switched off will not start, sometimes it will sounds like it wants to go but only if you done about 50 miles in it down the motorway, I put a clear fuel line from the return lines to fuel filter and fuel was pumping through as turning over, air in the line also which I managed to clear but still it wasn't interested
