2003 Transit: Wiper squirter motor
Postby wanderer 999 » Thu May 08, 2025 10:45 am
Hi there,
Trying to troubleshoot why water is not pumping up from the wiper squirter water tank. I can blow air through the hose to the squirter nub below the windscreen and there is power going to the squirter motor. It sounds like it is working but its not pumping water up the hose, so am I to assume it is kaput? Photo of pump attached.
wanderer 999
Re: 2003 Transit: Wiper squirter motor
Postby andz327 » Thu May 08, 2025 11:05 am
If the pump filter on the inlet hole of pump or in hole the pump locates into isn't blocked and power definitely getting to pump then sounds like it's the pump isn't strong enough to send water to the washer jets.... replace pump
andz327
Postby wanderer 999 » Thu May 08, 2025 1:21 pm
thanks for that, I can blow air through the pump so looks like a replacement!
andz327 wrote:If the pump filter on the inlet hole of pump or in hole the pump locates into isn't blocked and power definitely getting to pump then sounds like it's the pump isn't strong enough to send water to the washer jets.... replace pump
wanderer 999
Postby gt_addict » Thu May 08, 2025 1:34 pm
Had this last year. I had switched to a different screen wash andnit had made a gloopy gel type substance in the washer bottle. Had to stick my finger in the rubber grommet and pull it all out. Then flush with just water.
gt_addict
Postby andz327 » Sat May 10, 2025 2:31 am
wanderer 999 wrote:thanks for that, I can blow air through the pump so looks like a replacement!
Is the filter clean
andz327
