Head gasket gone, replacement engine
Postby AMG » Wed May 21, 2025 5:13 pm
Hi
My 2008 Transit 85 T280 FWD Refrigerated Van, has a blown head gasket, It's at 160K miles so I have been advised a replacement engine is the way to go, but I'm open to suggestions.
The help I need is recommendations for a transit specialist to carry out this work in the south Wales Area.
All help appreciated.
thanks
AMG
Re: Head gasket gone, replacement engine
Postby DanMK7uk » Wed May 21, 2025 7:02 pm
Without saying it has not failed what was the symptoms ?
Pretty un usual for them to go on these.
DanMK7uk
Postby vansit1 » Wed May 21, 2025 7:18 pm
why is it called t280?
vansit1
Postby knobby1 » Wed May 21, 2025 7:54 pm
vansit1 wrote:why is it called t280?
Max vehicle weight is 2800kg.
Mine is a T350, so 3500kg max.
Postby knobby1 » Wed May 21, 2025 7:59 pm
AMG wrote:Hi
thanks
Curious....Transit head gaskets very rarely fail...They're not like the "old type" gaskets, they're a layered steel setup......what symptoms are you getting..??
Postby AMG » Thu May 22, 2025 6:59 pm
It overheated 1 day out of the blue and I noticed the coolant tank was empty. Since then it’s hard to start, loads of smoke out of the exhaust, mayo on the oil cap and it failed the pressure test.
But I’m sure the specialist would still check before starting the work.
AMG
Postby DanMK7uk » Thu May 22, 2025 8:02 pm
Get your mechanic to check !
DanMK7uk
No visible leaks can sometimes be attributed to the EGR cooler internally leaking, you can bypass them mate.
It could well be that…
DanMK7uk
Postby metalworker0 » Thu May 22, 2025 8:34 pm
EGR cooler failure would not give him mayo in the oil ..
Think its quite conclusive on this one that the head gasket has failed, or it has cracked head or block.
Postby DanMK7uk » Thu May 22, 2025 9:15 pm
metalworker0 wrote:EGR cooler failure would not give him mayo in the oil ..
Certainly got the symptoms but not conclusive IMO,
condensation could… short trips..
Regardless
First thing id be doing is bypass cooler, refill and bleed. Go from there.
Cheers
DanMK7uk
