T350camper wrote:Hi. Really need to know which Transit you have (FWD RWD, which model year etc). Later Transits use 5W30 synthetic oil (maybe different in a hot climate?). A video with sound file would help. Plenty of knowledgeable people on here.
metalworker0 wrote:he is in spain so his oil grade should be just about OK, i think.
sometimes it can leak around the injector seals and make tapping noises, this will be accompanied by chuffing out of the oil filler when you remove the cap.
chuffing = like puffing , steam locomotive etc
says in the haynes this oil can be used
https://haynes.com/en-gb/tips-tutorials ... 013-models
T350camper wrote:It does sound like top end to me on that video. Maybe a hydraulic tappet that's not operating correctly?
metalworker0 wrote:the other sound, other than the taps, sounds like the power steering pump . - not a worn one but one with air in the system ..that's the noise mine made when i first did the steering fluid change ..until all the air was out, and it stopped frothing . .
metalworker0 wrote:I think you are going to be taking the rocker cover off .
