Background info. Had a new egr fitted and a boost pipe from inter to inlet. I have the spanner on with the following code p1103 mass air flow sensor in range/higher than expected.
So I changed. Sensor to a non gen sensor , cleared the spanner (brake/accel). And fired it up. No spanner. Drive for half an hour. Everything seems fine.
Turn off. Go for a cuppa and come back . Fire it up and immediately the. Spanner comes on. With the same code . On tick over the maf reading is between 14 and 16. At 800rpm.
Any help to keep spanner off would be appreciated I’m in SHEFFIELD UK
