Code P2598 turbo boost control stuck low
Postby Bignorm68 » Fri May 30, 2025 11:45 am
Hi folks I have the code P2568 turbo boost control stuck low,most the chat pointed towards the actuator which I have replaced and still getting the code at random intervals while driving, the traction control does come on with the eml warning, and it recycles on turn off of ignition while driving but does return at different times.
Some say it's a generic code not sure wot that means am no auto spark,
Did anybody ever get a answer to wot the problem was or might be the cause.
Van is 2013 2.2 euro 5
Bignorm68
Re: Code P2598 turbo boost control stuck low
Postby tranmx2 » Fri May 30, 2025 11:56 am
P2568 shows as for catalyst temp.
The 2012 Transit does not have any sensors near the catylytic converter.
Is the turbo actuator easy to replace?
2012 MK 7 E 5 100-350 3.5 XLWB RWD Duratorq 2.2L CR TC 14 DSL 100/125 PS
Was DRRB 74 KW 100 HP 100 cv. Now CYR5 125 HP. PCM could still be for 100 HP. Siemens Continental fuel system.
OBD2 ELM 327 FTDI with switch from Tunnel rats. Forscan 2.3.46
tranmx2
Postby gt_addict » Fri May 30, 2025 12:57 pm
Check your wiring and actuator arm are good at the turbo first off.
gt_addict
Postby gt_addict » Fri May 30, 2025 6:24 pm
Have a watch of this from Orileys Autos.
https://youtu.be/jCYEX0Ab2d8?si=7AcN8D_fzwtVjUJ3
gt_addict
Postby Bignorm68 » Sun Jun 01, 2025 8:52 am
Bignorm68 wrote:Hi folks I have the code P2598 turbo boost control stuck low,most the chat pointed towards the actuator which I have replaced and still getting the code at random intervals while driving, the traction control does come on with the eml warning, and it recycles on turn off of ignition while driving but does return at different times.
Bignorm68
Postby Bignorm68 » Sun Jun 01, 2025 8:57 am
Hi folks the actuator was easy changed only took a few mins, the arm itself is free no sticking wot so ever,will check all the wiring today right back to source.
Bignorm68
Users browsing this forum: Altransit, Burra, Google Adsense [Bot], Trev_
