Update on. Spanner light. On a 2008 mk72.4rwd5 speed.
So. Brake +accel. Turn spanner light off go for drive. For 1/2/3 hours. No spanner light on. Stop, restart , Spanner light on. Code is. Air flow within range but higher than expected. . Now. It pulls good. No smoke .
I thought this so odd. That the spanner light doesn’t come on, on a drive. So I tried this….
Clear spanner. Ignition on, but do not start it, ecu doesn’t checks and all lights. Except oil/batt/handbrake go out. Turn off ignition. 10 secs later repeat . But don’t start engine. Again all lights go out except as above. Did that 5 6 or 7 times and they all went out then All of a sudden they all went out. Except spanner oil batt and brake . That’s without even starting van .
So ecu is doing its checks . What is anyone’s thoughts on this . If I fire up and drive when the spanner has gone out, it won’t appear untill I stop and restart
Thoughts please.. proper conundrum
