You could jack it up and turn each wheel listen for rumble , feel drive shafts for excessive play
Easier for me just to paste in here what the net says about it as ..its been explained better than i could many times . so why type it all out when its all ready created.
You could also watch youtube videos on how to inspect. example
https://www.youtube.com/shorts/UV9E1JBBMZMWhat google says :
AI OverviewThe Common Signs of Driveshaft Problems - Driveshaft UK
A failing drive shaft in a front-wheel drive (FWD) vehicle can manifest in several ways, including vibrations, shuddering, difficulty turning, loud clunking noises, and a squeaking sound. These issues often arise from worn bushings, U-joints, or slip yokes within the drive shaft.
Symptoms of a Failing Front Drive Shaft (FWD):
Vibrations and Shuddering:
Intense vibrations and shuddering, especially when accelerating or at higher speeds, are common signs of a failing drive shaft.
Difficulty Turning:A failing drive shaft can make it difficult to turn the vehicle, as the wheels may not receive the proper amount of torque.
Loud Clunking or Knocking Noises:
Loud clunking or knocking noises, particularly when turning, can indicate worn U-joints or slip yokes.
Squeaking Noise:
A squeaking noise, especially when accelerating or turning, may also indicate a problem with the drive shaft, potentially due to worn bushings or bearings.
Shuddering Upon Acceleration:
The car may shudder upon acceleration, especially if the driveshaft is vibrating excessively.
Loss of Power:In severe cases, a broken drive shaft can lead to a complete loss of power to the front wheels.
Possible Causes:Loose or Broken Components:Loose or broken components, such as bolts or mounting brackets, can also contribute to drive shaft issues.
Consequences of Ignoring a Failing Drive Shaft:Damage to Other Components:
Excessive vibration from a failing drive shaft can cause damage to other components of the drivetrain, such as the transmission or differential.
Steering and Handling Issues:A failing drive shaft can make it difficult to steer and handle the vehicle.
Increased Risk of Accidents:
A broken drive shaft can lead to a complete loss of power and control, increasing the risk of accidents.
Recommendations:
If you experience any of the symptoms listed above, have your vehicle inspected by a qualified mechanic as soon as possible.
Do not delay repairs, as ignoring a failing drive shaft can lead to further damage and potential safety hazards.
Steering Alignment or Drive Shaft Issue?
7 Sept 2022 — The most obvious symptom of a bad driveshaft is when you have trouble with turning your vehicle. Your wheels won't rece...
There are several signs of drive shaft problems, on front-wheel drive vehicles, one is vibration whilst driving in a straight line, normally it starts with a slight vibration at 20, 30, 40, 50 or even 60mph. You can usually drive through it, but it will reappear when you get back to that speed, if still under load.
Testing a Front-Wheel-Drive (FWD) driveshaft failure involves inspecting for common issues like vibrations, noises, and turning difficulties. A failure analysis can also be conducted to determine the mode, cause, and root cause of the failure.
Detailed Inspection and Testing:1. Visual Inspection:
Check for any visible damage to the driveshaft, CV joints, or related components.
2. Noise and Vibration Testing:
Listen for clicking, knocking, or grinding noises while cornering, which can indicate worn CV joints. Check for vibrations that intensify with speed, which may suggest loose joints or a bent shaft.
3. Turning and Steering Tests:
If the vehicle has difficulty turning or the steering feels stiff, it could indicate a drive shaft problem restricting normal wheel movement.
4. Rotation and Movement Checks:
Manually inspect the U-joints or CV joints for excessive play or movement.
5. Root Cause Analysis:
If a failure is identified, a root cause analysis can be conducted to determine the underlying reason for the failure. This may involve comparing the failed part with a known good one, duplicating the failure, and analyzing the vehicle's design, operation, and environment.
me speaking now, not included in above
find car park ...drive round in circles with steering on maximum lock, in each direction, knocking indicates the outer cv joint has had it.
