So I have a mk7 2012 140 sport fwd. I've had loads of issues with this van that I've mentioned in other posts. I downloaded the Forscan light app onto my samsung android and bought a bluetooth linker so I could read the codes as I'd got the orange engine light on and the red info light with the meassege "Engine Malfunction". I can't remember the exact codes but I'd got a soot accumulation, a forced limited power and an open circuit on the fuel vaporiser glow plug. So I fitted a new vaporiser, got a Ford one so I wouldn't have to buy again too soon.
Took it for a spin but it wouldn't do a regen so I did a forced one using the Forscan app. Mad or what? Took about 40 minutes sat there revving itself at 2500 rpm. Eventually it shut down and recommended it ticked over for a few minutes, which I did. Checked the codes again and got an all clear. So switched it off and left it for about 20 minutes while I cleaned up.
Got in it to come home and it wouldn't start, B***ard. Checked the codes and got "Injector fuel pressure too low". I can't remember the exact code and I left the piece of paper at the workshop. Had to cycle home, B***ard again.
Any ideas what would cause this? Maybe this could be the problem I've had all along. It's been a bit noisy. Ticks over fine and revs on the spot fine. Go for a drive with a very genlte throttle and it's fine. Press the throttle to accelerate moderately and it kind of sounds like there's a cracked exhaust manifold, or a small hole in the exhaust somewhere.
Any ideas?
I bet it starts first time in the morning after it's been stood all night.
