Salisburytree wrote:I will double check mine however I'm sure there are no recesses. Iv never noticed any leaking, the previously fitted was similar yet had a rather thin gasket
Some use a steel gasket, other have a steel gasket with rubber O-rings moulded into it, have also seen a fiberous type gasket used....there's lots of different manufacturers for them.
This is the most common one I see for pumps without the O-ring recesses, with the moulded in O-ring/seals:
Then theres the plain flat one which some use with the O-rings:
And another plain flat one, not sure if it's supposed to be used with O-rings or not.
As mentioned, I don't use a gasket of any kind on mine, just O-rings, and it hasn't leaked since fitting it several years ago.
