2002 T280 dies after few minutes
Postby blueyT280 » Sat Jun 14, 2025 4:50 pm
Hi,
I recently bought a camper-converted 2002 Transit T280.
It has this bizzare issue where it will start fine, idle for about 5 minutes, and then the revs will start to fluctuate a bit before it finally dies. The throttle cable also becomes unresponsive during this time, flooring it has no effect on the revs.
It then refuses to start again until I leave it for a few hours, or until the next day.
Any ideas where I should start looking first? Got a generic OBD reader but it doesn't seem to work with the Transit.
Many thanks
blueyT280
Re: 2002 T280 dies after few minutes
Postby knobby1 » Sat Jun 14, 2025 9:44 pm
blueyT280 wrote:Hi,
Many thanks
What actual reader did you use..?? Mk6 Transits are "NOT" OBD-II compliant, so most of the newer readers won't work. You need Forscan or IDS. Is the glow plug light flashing fast..??
They don't have a throttle cable either..they have an electronic throttle pedal.
Postby DanMK7uk » Sat Jun 14, 2025 11:58 pm
Could really do with some diagnosing with software but when was the fuel filter last changed ?
DanMK7uk
Postby blueyT280 » Sun Jun 15, 2025 12:27 am
Thanks for the replies.
The OBD reader I have is a cheapy Amazon one, so it probably isn't compatible with the Transit.
And yes you're right, it is an electronic throttle, and it seems to ignore any input when the revs start fluctuating.
I had it serviced when I bought it a few weeks ago, and they were supposed to change the fuel filter then
blueyT280
Postby knobby1 » Sun Jun 15, 2025 5:54 am
blueyT280 wrote:Thanks for the replies.
You need proper diagnostics on it...not just a cheap reader...get Forscan and do it yourself, it's free to downloasd and the cable is cheap.
Lord Knobrot.
Postby blueyT280 » Sun Jun 15, 2025 5:11 pm
Lord Knobrot.
Thanks for the advice. I'll get one ordered ASAP.
In the meantime, is there anything else I can/should check?
blueyT280
Postby DanMK7uk » Sun Jun 15, 2025 5:52 pm
Its all a guessing game really. Best thing is get it plugged in to forscan when your cable comes and deal with what it shows
DanMK7uk
Postby blueyT280 » Sun Jun 15, 2025 6:56 pm
Just went out and tested the battery, it's showing around 11v with the ignition off and under 10v when cranking, so I've definitely got a bad battery.
I connected my trusty booster pack up, and it cranked and cranked, but refused to start up.
Would having a bad battery, regardless of using a booster pack, cause the van to cut out and not start again?
blueyT280
Postby metalworker0 » Sun Jun 15, 2025 7:20 pm
Ideally you need to do some more tests when running ..to work out if the battery is being charged. (plus 14 volts) ..if you are in the situation of low battery and not being charged, the van will break down as you have been .,, as not enough voltage to keep the electronics happy .
with the jump start in place should start , maybe needs more persistence or better more powerfull jump start set up, as it needs to turn over fast not slow.
Postby knobby1 » Sun Jun 15, 2025 8:02 pm
blueyT280 wrote:Just went out and tested the battery, it's showing around 11v with the ignition off and under 10v when cranking, so I've definitely got a bad battery.
No. If the battery was that bad, it wouldn't start in the first place. Good batteries are basically essential on a Transit. Often a poorly starter can be amongst other issues related to poor starting too, it may turn over fast enough but if it's pulling more current than would otherwise be the case, it drags power away from the pump electrics and they can fail to start because of it. Under 10v during cranking is just not going to do it.
As our Dan says, you need to get the fault codes read and work from there....guessing is pointless.
