2010 MK7 seat belt light
Postby Moonscross » Sun Jun 29, 2025 1:51 pm
Hi
I have an annoying permanent seat belt indication on the dash even when key is out.. :(
i have done the following but light persists:
I have checked, as best i could, the seat buckles and have cleaned them
removed battery to reset the BCU/ECU
Seems this is driving towards a faulty occupancy sensor (seat pressure pad on the passenger seat) however this is embedded in the seat itself and i cant locate any wiring loom under the seat
I also cant find any wiring diagrams relating to this... :(
Any ideas on how to resolve this issue..?
Moonscross
Re: 2010 MK7 seat belt light
Postby DanMK7uk » Sun Jun 29, 2025 11:17 pm
Is it not the air bag light ?
DanMK7uk
Postby knobby1 » Mon Jun 30, 2025 1:51 am
Moonscross wrote:Hi
Removing the battery to reset the BCM/ECU does nothing except require you to reset the clock and radio code. It does not reset the PCM or BCM....they don't have an ECU as such.
Are you sure it's not an airbag light?? Some Transits don't have seat occupancy lights....mine doesn't.
Postby Moonscross » Mon Jun 30, 2025 2:21 pm
Hi
Thanks for your replies...
pretty sure its the seat belt light, i have taken a pic but unable to load on this reply..
Its a red indication of a person sat on a seat with a seatbelt, which is different to the yellow air bag warning indicator ..
Moonscross
Postby Moonscross » Mon Jun 30, 2025 2:29 pm
Hi thanks for your replies
Pretty sure its the seat belt warning indicator...have been trying to upload a pic onto this reply but unable to..more than likely me.
Indicator which is permanently on is red and depicts a person sat on a seat with a seat belt..which is different to the yellow airbag fault light
Moonscross
Postby tranmx2 » Mon Jun 30, 2025 10:25 pm
viewtopic.php?f=2&t=185695
I have a 2010 SWB Fwd 2.2 140 and the airbag light is on. From the above post.
From the owners manual which is used for the 2012 Transit.
Seat belt warning - internet image could be Ford.
If you have Forscan you could read the DTCs.
2012 MK 7 E 5 100-350 3.5 XLWB RWD Duratorq 2.2L CR TC 14 DSL 100/125 PS
Was DRRB 74 KW 100 HP 100 cv. Now CYR5 125 HP. PCM could still be for 100 HP. Siemens Continental fuel system.
OBD2 ELM 327 FTDI with switch from Tunnel rats. Forscan 2.3.46
tranmx2
Postby Moonscross » Tue Jul 01, 2025 7:54 pm
Definitely the seat belt warning light...anyone have any ideas..?
It must be linked to a seat pressure pad and somehow locked in as it stays on even when all seat buckles are made and ignition off
Im assuming the wiring for this pad is fed through the belt tensioner underneath the seat, however nothing obvious... :?
Moonscross
Postby knobby1 » Tue Jul 01, 2025 8:03 pm
Moonscross wrote:Thanks
If it has a seat pressure pad, it must have a wire loom to it under/around the seat somewhere...have you removed the offending seat..??
Users browsing this forum: Google Adsense [Bot], metalworker0
