An annoying issue with my van that's been bothering me for a while now. It's not always there, which makes it difficult to find and solve. Here it is:
Sometimes when i'm driving the van, it seems like there's a little loss of power, you've got to press the throttle a bit further to accelerate or maintain speed so that's obvious. Now, when that happens and i want to change gear or slow down, i can also feel that those pedals are "softer". It's almost like there's air in the brake and clutch system. Obviously i checked to see if there's air in the system but there is no air. Most of the times the pedals are as hard as they should be and the van will respond to the throttle like normal. I can imagine that if there's something wrong the ECU cuts throttle response for whatever reason, but so far i haven't been able to find the cause of this issue.
Anyone ever had this with their Transit, and if so, could you maybe give me a hint as to what could be causing this? Could it for example be a small vacuum leak somewhere?
before anyone asks: I can always bring the van to a safe stop, for me there's no worries about safety but obviously there's something that needs fixing.
After a drive when i shut down the engine and press the brake pedal, i have heard some air at the pedal box but that's not been the case recently.
Hopefully some of your Transit experts can give me a hint in the right direction
