Hi,
I'm trying to add front Parking Aid sensors to my MK6 2.0DI 100PS 2005 transit van and it has a connector for plugging in the the Ford Parking Aid module and sounder under the facia on the left side of the vehicle, I'm struggling to find where the wires for the sensors go after disappearing through the firewall.
I have the module/sounder and the parking sensors, I just need to work out the wiring to connect them together.
I would be grateful if someone who has Ford front parking sensors could let me know where the connector is under the bonnet for plugging in the parking sensor loom that I presume I'll have to make up to connect the parking sensors.
I could also do with knowing where on the bumper I need to drill the holes as even though I can find reference to original front bumpers with holes for parking sensors I haven't found any photos.
A wiring diagram showing the wire colours and connectors between the parking aid module and the sensors would also help me to locate the wires under the bonnet.
Any help on the wiring would be appreciated as it will save me from having to remove the tape from around the wiring loom under the bonnet and trace them manually.
Best regards
Trev
