No power steering on start up
Postby DanMK7uk » Fri Aug 01, 2025 10:39 pm
Hello guys,
A friend of mine has a euro 4 mk7 fwd… but not on the forum himself. Said id ask for him.
He reports when starting up, and at first taking off the steering is heavy once moving the power steering kicks in…
Got fluid in reservoir, said it looks dark so advised him to change it for a kick off as part of good service/ maintenance.
Any other possibilities ? Sticking pump perhaps ? No squeaks / slipping belt type noises…
Cheers.
DanMK7uk
Re: No power steering on start up
Postby dumper » Sat Aug 02, 2025 5:34 am
Yes start by changing the oil if that doesn’t work could be pump getting weak or the balljoints tightening up Jack it up before starting the engine and see if there is anything that feels amiss
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby DanMK7uk » Sat Aug 02, 2025 11:33 am
dumper wrote:Yes start by changing the oil if that doesn’t work could be pump getting weak or the balljoints tightening up Jack it up before starting the engine and see if there is anything that feels amiss
Cheers, interesting point re balljoints.. il put that to him. Definitely wants some fresh oil to..
Cheers
DanMK7uk
Postby dumper » Sat Aug 02, 2025 7:16 pm
The balljoint is a slim chance but a possibility go for the oil first
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby DanMK7uk » Sat Aug 02, 2025 9:57 pm
Apparently he has done the oil today, will post up on results cheers
DanMK7uk
Postby knobby1 » Sat Aug 02, 2025 10:04 pm
DanMK7uk wrote:Apparently he has done the oil today, will post up on results cheers
Will more than likely be the rack itself...the internal seals leak when standing for several hours or overnight....and when starting from cold you have the same pressure on each side of the ram....once the steering pump starts, the pressures slowly come good and the steering returns to normal.
Postby DanMK7uk » Sun Aug 03, 2025 12:08 am
Good evening or morning in your case knobby, very interesting. Il pass that info on.
Cheers mate
DanMK7uk
