A couple of codes.
A couple of codes.
Postby DanMK7uk » Sun Aug 03, 2025 11:25 am
Hi guys,
Couple of codes showing on forscan as follows.
P068A:00-28 ECM/PCM Power Relay De-Energized Performance - Too Early
P0480:14-28 Fan 1 Control Circuit Additional Fault Symptom
- Circuit Short To Ground Or Open
Starter intermittent clicking.
Battery 6 months old and load tested all ok
Terminals clean and tight..
Any pointers would be great
Cheers
DanMK7uk
Re: A couple of codes.
Postby metalworker0 » Sun Aug 03, 2025 2:18 pm
According to Google AI both fan and pcm could be caused by pcm relay or wiring.. pcm relay will be in the engine fuse box ... cant tell you what relay number is because you haven't stated year of van
if not any of those two , it says its the pcm at fault
but slowly learning about these transits .. i would look at the battery relay first .. the one that connects the two batteries together. that is because of your starter issues ..
but also here are loads of references to the ignition switch causing faults ..
as its all related to failure of power supply to pcm, and you've checked the earths and large positives, so could be any one of that lot, is my best guess .
Postby DanMK7uk » Sun Aug 03, 2025 2:44 pm
metalworker0 wrote:According to Google AI both fan and pcm could be caused by pcm relay or wiring.. pcm relay will be in the engine fuse box ... cant tell you what relay number is because you haven't stated year of van
Hi mark cheers for that.
I cleared dtcs, started up the van a few times all ok. Soon as clicking started code came back..
So that explains that.
Vans 2008. Single battery on this ol girl.
Cheers
DanMK7uk
