Oil Temp Sensor 2.4 TDCI MK7
Postby Burn2 » Sun Aug 10, 2025 5:42 pm
Hello,
So i am back for one other question. :)
So on my transit 2.4 tdci 140 (2008/2009) i got an EOT Value in forscan (so Oil temperature).
Does the 2.4 TDCI got one? Is it something calculated like ECT?
The sensor seems to sometimes report bad temp for example it could be stable at 86 then sundunly low in a short way until 55° then goes high in a short time.
For example: Engine is hot ( running since a long time), outside temp is 31°: it report a stable 87/86 value then...
Code: Select all
87
87
87
87
87
87
87
87
87
87
87
86
86
86
86
86
86
83
81
78
75
73
70
68
65
62
60
57
59
61
63
65
67
69
71
73
75
77
79
79
79
79
79
79
79
79
79
79
79
79
77
75
73
71
69
68
66
64
62
60
58
58
57
57
57
56
56
55
55
55
54
54
57
61
64
67
70
74
77
80
83
87
90
90
90
90
90
90
91
91
91
91
91
91
91
91
On the same travel an other time: like i said 31° outside temp.
Code: Select all
84
84
84
84
84
84
84
84
84
84
78
72
66
60
54
47
41
35
29
23
17
18
18
19
19
20
20
21
21
22
22
23
22
22
21
21
20
20
19
19
18
18
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
16
16
16
16
16
16
16
16
16
16
16
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
16
16
16
16
16
16
16
16
16
16
16
15
15
15
15
15
15
15
15
16
16
16
16
16
16
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
18
18
18
19
19
20
20
20
21
21
21
21
21
21
21
20
20
20
20
20
20
20
20
20
20
20
19
19
19
19
19
19
20
21
22
23
24
26
27
28
29
30
31
30
30
29
28
28
27
27
26
25
25
24
25
25
26
27
28
28
29
30
31
31
32
33
35
36
37
38
40
41
42
43
45
46
49
51
54
56
59
61
64
66
69
71
74
71
68
65
62
59
56
53
50
47
44
41
41
41
41
41
41
41
41
41
41
41
41
45
48
52
55
59
62
66
69
73
76
80
80
80
79
79
79
79
79
79
78
78
78
78
78
78
78
78
79
79
79
79
79
79
79
80
80
80
80
81
81
81
81
82
82
82
81
81
81
81
80
80
80
80
79
79
79
79
79
79
79
80
80
80
80
80
80
80
81
81
81
82
82
83
83
83
84
84
84
83
83
83
82
82
81
81
I take a look on car cat info but i am not sure to find the correct sensor.
Did you ever see such result on the oil temp sensor?
Does the engine use the sensor for other things then detect an overheat on oil? For exemple does the engine use it to know if the engine is at low temp? (i think it's more the CHT Sensor that is used but??? )
Other temp are totally normal and does not move like that, only oil temp does that.
Thank's a lot.
Burn2
Re: Oil Temp Sensor 2.4 TDCI MK7
Postby metalworker0 » Sun Aug 10, 2025 6:28 pm
At an outside temperature of 31 it should never show 15 even from a cold start or a stuck open thermostat, so sensor is at fault ..
sorry cant help you with part numbers, they are in catcar.info .. a site i can no longer get into.
https://www.catcar.info/ford/?lang=en
Postby knobby1 » Sun Aug 10, 2025 8:03 pm
Burn2 wrote:Hello,
Code: Select all
87
87
87
87
87
87
87
87
87
87
87
86
86
86
86
86
86
83
81
78
75
73
70
68
65
62
60
57
59
61
63
65
67
69
71
73
75
77
79
79
79
79
79
79
79
79
79
79
79
79
77
75
73
71
69
68
66
64
62
60
58
58
57
57
57
56
56
55
55
55
54
54
57
61
64
67
70
74
77
80
83
87
90
90
90
90
90
90
91
91
91
91
91
91
91
91
Code: Select all
84
84
84
84
84
84
84
84
84
84
78
72
66
60
54
47
41
35
29
23
17
18
18
19
19
20
20
21
21
22
22
23
22
22
21
21
20
20
19
19
18
18
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
16
16
16
16
16
16
16
16
16
16
16
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
15
16
16
16
16
16
16
16
16
16
16
16
15
15
15
15
15
15
15
15
16
16
16
16
16
16
17
17
17
17
17
17
17
17
17
17
17
17
17
17
17
18
18
18
19
19
20
20
20
21
21
21
21
21
21
21
20
20
20
20
20
20
20
20
20
20
20
19
19
19
19
19
19
20
21
22
23
24
26
27
28
29
30
31
30
30
29
28
28
27
27
26
25
25
24
25
25
26
27
28
28
29
30
31
31
32
33
35
36
37
38
40
41
42
43
45
46
49
51
54
56
59
61
64
66
69
71
74
71
68
65
62
59
56
53
50
47
44
41
41
41
41
41
41
41
41
41
41
41
41
45
48
52
55
59
62
66
69
73
76
80
80
80
79
79
79
79
79
79
78
78
78
78
78
78
78
78
79
79
79
79
79
79
79
80
80
80
80
81
81
81
81
82
82
82
81
81
81
81
80
80
80
80
79
79
79
79
79
79
79
80
80
80
80
80
80
80
81
81
81
82
82
83
83
83
84
84
84
83
83
83
82
82
81
81
Thank's a lot.
They don't have an "oil temp sensor". They only have a CHT.
They have an oil level sensor though:
#6C624 here: https://www.catcar.info/ford/?lang=en&l ... E2OTArMTMz
Postby Burn2 » Sun Aug 10, 2025 10:53 pm
Hello.
Thanks for the answer.
I have seen the oil level sensor and if i am not wrong they have a oil presure sensor too?
So an other ecu calculation but that seems to be wrong.
I don t know why ford has done such things if value brings nothing like that.
Does your transit report such bad value for the "eot" temp?
Burn2
Postby andz327 » Mon Aug 11, 2025 12:37 am
Burn2 wrote:Hello.
Where??
andz327
Postby knobby1 » Mon Aug 11, 2025 3:45 am
Burn2 wrote:Hello.
All Transits have an oil pressure sensor.
I've never seen engine oil temp anywhere in Forscan...although, I've not looked for it. Can only be within a couple of degrees of the coolant temp due to the oil cooler.
Postby Burn2 » Mon Aug 11, 2025 9:35 am
I don t know why there is such big difference from some transit.
In mine i got:
Iat ( seems to be in maf sensor but not sure, could be the outside temp )
Iat2 ( in the map sensor )
Frp temperature ( fuel temp, in the frp sensor )
CHT ( cylinder head temperature )
ECT ( calculated from cht so an estimation from how cht change )
EOT ( as there is no sensor, should be caculated from CHT? Should be something estimated too, but the calculation seems to be totally erratic sometimes )
I wonder if the pcm firmware does not change a lot of things and could not improve the "estimated value" like ect/eot or remove one of them ( if you do not have eot on your's )
Related to oil, does all the 2.4 with cooling oil system have an oil thermostat on it? How do you find if it's stuck closed?
Is it something know to be problematic like cooling thermostat?
Burn2
Postby knobby1 » Mon Aug 11, 2025 7:54 pm
Burn2 wrote:I don t know why there is such big difference from some transit.
Yes, all 2.4 Mk7's with OEM cooler with the plastic oil filter housing have an oil thermostat....the later OEM "modified" and non-OEM coolers with the spin-on metal oil filters do not. My oil cooler does not have a thermostat...my original one did.
Mine is now like this one:
The thermostat on the original OEM cooler assy's is known to leak from the O-ring, but not fail as such.
I wouldn't worry about the "guesstimated" oil temperature, it will never get high enough to casue any major issues ....you cannot control it anyway...unless you run another separate oil cooler system..pointless really.
Postby Burn2 » Mon Aug 11, 2025 11:02 pm
Thank's for the information.
Burn2
