2008, Single rear wheels Long Wheelbase 2.4 6 Speed Panel van 95K miles
I have a suspect bearing noise from the rear axle. I have changed both wheel bearing whilst changing disks so have eliminated them as a possible cause.
The oil level is correct
I suspect the Diff or prop shaft but there is no obvious play on prop shaft.
Mild rumble start about 3oMPH and get louder up 60 then levels off. Not much difference in noise on acellerate or decelerate.
As the noise is more a rumble that a wine I suspect it is the Diff Bearings rather than crown and pinion ??
I don't really want to just buy a second hand axle as that diff may also be worn out.
I see bearing kits are available but cant find any guide on how to rebuild the diff .
I have a good collection of tools and feel I could rebuild a diff with right guide
Anyone provide a guide on how to rebuild together with torque, backlash settings etc?
