The power steering on my Mk7 2.2 RWD 125 T 350 is leaking, it's confirmed as the pipes rather than the connection.
I'm going to replace both pipes, the parts are 1730625 (high pressure) and 1582833 (low pressure).
All the images I can find of the parts show them with o-rings on the connections, but the exploded diagram I have found has part numbers for the o-rings (and even a part number for both o-rings as a pack). Can anyone confirm whether the o-rings are included?
When I spoke to Arnold Clarke, they wouldn't give me part numbers, but said I would need the 2 pipes and single use nut (no mention of o-rings), but I can't find this single use nut on the exploded diagram. Anyone got a pointer/part number for this mystery nut?
Ford prices to the garage are apparently in the > £300 range
Arnold Clarke £267 - next day
shop.ford.uk £183 - not including the mystery nut or any specific o-ring, genuine parts, 3 day delivery
autocarpart.co.uk £118 - not including the mystery nut or any specific o-ring, aftermarket parts, next day delivery
Anyone used autocarpart? Would you risk aftermarket parts? Anywhere else you'd recommend going to instead?
Tom
