Clutch pedal thudding & scratchy sound on idle
Postby samc1992 » Fri Sep 26, 2025 5:26 pm
Hello folks, I have a problem that I need some of your insight on. When the van is at idle and in neutral, if I rest my foot on the clutch pedal I can feel a thudding, like someone is tapping my foot with a hammer very lightly. There's a slight scratchy/tappy noise coming from around the clutch/flywheel area, but it's not obnoxious. Sometimes I'll struggle to get into 1st and reverse gear. If I press the pedal in the noise goes away, and when I pull the pedal up it comes back.
Model is Mk7 2.2 TDCi 85 Euro 4 FWD. It has a single mass flywheel with a non-dampening crank pulley. Originally I thought it was a failing DMF, or the rubber had perished on the crank pulley but my van doesn't have either of those things. Crank pulley doesn't seem to have any play in it from what I can see, and if I give it a wiggle it doesn't budge at all. I also considered whether it's the torque restrictor because sometimes it makes a "clanging" sound when changing gear, but I don't think that would cause the constant thudding on idle when stationary. Maybe I'm wrong. I plan to change the torque restrictor soon anyway.
Others have said it might be the spigot bearing, clutch splines are damaged, or "gearbox is buggered." I doubt it's a buggered gearbox because the van moves just fine, no other unusual or horrible noises, just that thudding through the clutch pedal that's bothering me, but I don't know enough about gearboxes and clutches to really say for sure.
Thanks all!
samc1992
Re: Clutch pedal thudding & scratchy sound on idle
Postby metalworker0 » Fri Sep 26, 2025 6:06 pm
release bearing ?
Sorry I don't know what a torque restrictor is .
spigot bearing ... hmm .. ive no experience of the symptoms of a bad one.
so you'll have to wait for someone else, who knows
Postby samc1992 » Fri Sep 26, 2025 6:11 pm
metalworker0 wrote:release bearing ?
Well if you think it might be the release bearing then I trust your insight, I'll look into it, thanks!
By the torque restrictor I mean the engine mount that fits underneath onto the gearbox.
samc1992
Postby metalworker0 » Fri Sep 26, 2025 6:51 pm
Yes .. i think the engine mount could play a part in this ... as the gearchange is cable.. and a moving mount would pull on the cables giving you an imprecise gear selection. . so maybe a combination of both, release bearing and mount if found to be loose and worn.
Hand brake on . you'll have to look down at the engine and observe the way it rocks, from a safe position , while you have someone , operating the clutch, and engaging the gears ... but not letting the clutch fully out as to stall it ... you want to be going into a forward gear , then reverse... etc, you'll be observing excessive rock of engine and box, if that torque mount is worn
Depending on what mileage at has on it .. could also have drive shafts that are worn... they would clunk and tap, inner joints all the time when in high gear, going slowly, lugging it at 20 mph in 5th would show up the beginnings of symptoms of driveshaft wear. clanging when changing gear being the take up of the slack of the wear and metal hitting metal.
Outer driveshhaft cvs, they would first show them selves when driving in tight circles' clunking will be heard.
When you have a van with high mileage .. lets say plus 180,000 miles .then there is possible wear on a lot of drivetrain components, all acting and culminating together. so hard to diagnose .
Postby knobby1 » Fri Sep 26, 2025 9:43 pm
What's a "torque restrictor"..?? Or are you talking about the lower geabox mount "dogbone"..??
Can't be the spigot bearing...FWD's don't have one. More than likely the release bearing or 1st motion shaft bearing not happy...either way, gearbox out to check/sort.
Postby samc1992 » Fri Sep 26, 2025 9:47 pm
knobby1 wrote:What's a "torque restrictor"..?? Or are you talking about the lower geabox mount "dogbone"..??
I think even you've called it a torque restrictor in previous threads, haha! Yes that one.
Okay good to have your insight on it, thanks! Release bearing seems to be mentioned a lot. Worst case scenario the breaker yard up the road has the exact same model Transit on 110k and I can have the gearbox off that.
samc1992
Postby andz327 » Fri Sep 26, 2025 9:53 pm
Personally I'd call it the engine steady bar or lower gearbox mount ...... never even heard of a torque restrictor lol
andz327
Postby andz327 » Fri Sep 26, 2025 9:57 pm
Wont be your gearbox ,5spd are quite reliable
Where in Glesga are you ?
andz327
Postby samc1992 » Fri Sep 26, 2025 9:59 pm
It's probably the only time this will ever happen on this forum, but I can smugly say that you are both wrong :lol:
samc1992
Postby samc1992 » Fri Sep 26, 2025 10:03 pm
andz327 wrote:Wont be your gearbox ,5spd are quite reliable
Aye it seems that way, and it doesn't sound or feel particularly nasty either. Just that thumping really.
I'm Southside, unfortunately there seems to be a severe lack of garages that either have availability or even want to work on an old van in general. I'm pretty keen to do this stuff myself, but this job specifically seems like a bit much to do on my own.
samc1992
Postby andz327 » Fri Sep 26, 2025 11:33 pm
I'm in east end and I'll give you a shout Tuesday or Wednesday and have look if you want mucker
Ps
I can honestly say I've never heard that part called that name and I've been on the tools for 44yrs lol but i guess thats what they are called......never even seen it on parts listing's until i checked after you said
andz327
Postby samc1992 » Sat Sep 27, 2025 2:26 pm
andz327 wrote:I'm in east end and I'll give you a shout Tuesday or Wednesday and have look if you want mucker
Ps
That's really good of you to offer mate, I never expected anyone to dedicate that much time to it! If you're up for it that would be amazing, you'll be able to tell what it is in no time. I'll send you a PM.
samc1992
Postby andz327 » Tue Sep 30, 2025 3:54 am
Try get to you Thursday
PM'd you
andz327
