The previous owner filled the internal channel with expanding foam which made the light fitting swell allowing water to gain entry.
This has popped/blown/burnt the light.
Upon inspection I have brought a new light unit however I am unable to plug and play because the two pins that have blown are stuck inside the live male end from the battery.
I have used a multimeter and the power levels and continuty are all good.
I am trying to located the generic ford two pin connector or maybe create a work around.
I wondered if anyone could help or had experience with this.
