knobby1 wrote:GrumpyOz wrote:Bit disappointed in mine too. 140/350, 2008 LWB high roof. Rarely any load above 200kg. Bought it with a whiny 4.27:1, was getting about 12l/100 with 90% highway use at 100-110km/h. Since swapped it for a much quieter 3.31:1, which has very nearly moved each gear up to the rev range of the next with the old rear. It has improved it very slightly averaging 11L/100, or I can bring that down to just under 10 if I really granny drive it, and I mean really gentle, like I'm trying to win a prize in an economy run.
With a 3.31 ratio and very little load you should be getting 8.5-9L/100km or ~33.2-35.3mpg on the motorway @~100kmh.
I get those numbers with a 4.27 diff with very little load in the back.
Something is not right. When were the learns last done, when were the fuel & air filters last replaced..?? Tyre pressures..??
Yeah, I was hoping to get it under 10 consistently with the recent work, and definitely something isn't right.
Had it nearly 4 years and it never was good. Recently gave it a new EGR as it threw a code a couple of times, had an idling issue last year, gave it a new SCV, PRV (which was blown out) at the same time. So while I was throwing a fortune at it, replaced the intercooler hoses both sides, and gave the intercooler itself a good clean. Turbo side hoses needed doing, as they were getting soft with oil contamination. Mann fuel filter and Ryco air filter replaced (again) at the time SCV was done, then learns. I was hoping for at least some improvement, but it's still drinking like a hobo. Tyres 50 front, 60 rear. No brakes dragging either. Trying all I can think of, and spending time learning stuff on this forum, and getting nowhere with it. Still relatively a pup, 314,000k. And as you say M'Lord, never get it over 2.5T compared to your 3.5, it should be doing better.
One thought has just come to mind, previous owner said he had the turbo replaced about a year before I bought it. Possibly an incorrect turbo?
