Rear axle ratio
Rear axle ratio
Postby shonkers » Mon Dec 01, 2025 4:47 pm
Hi all, I think my rear diff is shot there is about 2 inches of rotation on the prop before you get drive and if you let the clutch out sharply it makes a loud clunk so iv’e been nursing it along for now, iv’e found another one with a 5.? ratio forgot what he said actual ratio was and it’s off a 6 speed minibus with same 2.4 engine, my question is do you think it would be ok for me to use it? considering my diff has a ratio of 4.63
51 Mk6 2.4 tddi minibus remap by martyn Mk5 2.5 banana somewhere in africa now Toyota estate daily driver 88 Pug 205 gti wknd toy 05 z thou road bike 99 r6 trackbike 06 Sherco 450i + 98 Suzuki ts125 140cc monkey Nissan serena in ibiza
shonkers
Re: Rear axle ratio
Postby T350camper » Mon Dec 01, 2025 5:39 pm
Mine has a 5. something diff and the gearing is quite low (not silly, but I'd rather it was a bit taller). 6th gear will pull from 35mph. It depends on the speed you tend to travel at. I mainly cruise along at 55-60 (not in a hurry in a camper) but if you want to do 70, it might be a bit tiresome after a while.
2006 Mk6 T330 135bhp 2.4TDCI
T350camper
Re: Rear axle ratio
Postby knobby1 » Mon Dec 01, 2025 7:45 pm
shonkers wrote:Hi all, I think my rear diff is shot there is about 2 inches of rotation on the prop before you get drive and if you let the clutch out sharply it makes a loud clunk so iv’e been nursing it along for now, iv’e found another one with a 5.? ratio forgot what he said actual ratio was and it’s off a 6 speed minibus with same 2.4 engine, my question is do you think it would be ok for me to use it? considering my diff has a ratio of 4.63
Mk6 TDDi's only come in 3 ratios, 4.63, 5.13 & 5.14....the 5.xx ratios were maily for the tippers, campers, recovery and Luton type vehicles.....the 6 speed minibus would have been a 2.4 TDCi and had a Dana axle which had more ratios available. But the prop shaft will be different and slightly shorter as the 6 speed box is slightly longer than the 5 speed. Some people have gone for a Mk7 Dana rear axle but they have disc brakes....if you have ABS it can cause issues.
Re: Rear axle ratio
Postby shonkers » Mon Dec 01, 2025 9:18 pm
Ah right so the 5.11 and 5.13 would be shorter gearing which is not something i’d want i’ll see if i can find a 4.63 like mine, i’ll put a post up in the wanted section cheers for the replies chaps
shonkers
Re: Rear axle ratio
Postby knobby1 » Mon Dec 01, 2025 11:55 pm
shonkers wrote:Ah right so the 5.11 and 5.13 would be shorter gearing which is not something i’d want i’ll see if i can find a 4.63 like mine, i’ll put a post up in the wanted section cheers for the replies chaps
The 5.11 was never an option for the TDDi engined 2.4's, only 4.63, 5.13 & 5.14....but yeah, it'll be "revving it's tits off" @70mph with a 5.xx ratio diff.
Re: Rear axle ratio
Postby dumper » Tue Dec 02, 2025 7:28 am
It would be worth checking the price with a local to your axle specialist who can rebuild your axle
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Re: Rear axle ratio
Postby T350camper » Tue Dec 02, 2025 10:27 pm
I agree with dumper. There are gearbox/axle specialists that can rebuild these things to a very high standard...and then you know it's the right one.
T350camper
Re: Rear axle ratio
Postby shonkers » Thu Dec 04, 2025 11:20 pm
There’s a couple of places oop north who do the rebuild but it’s £800 ish plus i’d have to drive it there although there is the option where they come to you and do it in a couple of hours but i expect there would be travelling costs on top, kits have one for £350 and they’re on this forum so they must be kosher
shonkers
Re: Rear axle ratio
Postby dumper » Fri Dec 05, 2025 10:01 am
When you say up north if it’s Henderson Transmissions i have had work done by them and know of local garages that also use them and not heard of any problems.
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
