Unladen weight, mk7 lwb medium roof fwd
Postby mjsroofing » Sun Dec 07, 2025 12:11 pm
Does any one know what the unladen weight would be roughly,
I know I can go to weigh bridge , which i will at some point, i was just hoping someone would have already done it with their van and just happens ro know.
I just want to work out my tyre pressures.
www.mjsroofing.co.uk
2022 2.0 ecoblue fwd, 72k
2009 2.2 tdci 115ps just over 110k now.
2002 2.0 tddi 100ps. Over 205k still sweet . Now owned by Jay.
2001 escort van 75, 1.8 turbo intercooler. scrapyard heaven
1995 escort van 50, 1.8 straight diesel, scrapyard heaven.
mjsroofing
Re: Unladen weight, mk7 lwb medium roof fwd
Postby tranmx2 » Sun Dec 07, 2025 12:34 pm
Info' re' vehicle weights/payload etc is available on the net.
Transits are not the same. 2.6 2.8 3.5 DRW SRW SWB LWB XLWB which one do you refer to?
There's a lot to consider.
What do you mean by unladen weight?
The weight of the veicle before it is fully loaded.
Simply - full tank, driver and all the things usually in/on the vehicle the weight of which needs to be known is the weight of the vehicle before it is fully loaded - unladen weight.
The unladen weight and the payload.
The unladen weight of a 3.5 is say 2000 kg therefore the payload is 1500 kg.
The easiest way to know the unladen weight is to weigh it with all of its usual things in/on it. Lunch box and the feather the wren dropped.
Could get a load of sand from a merchants you'll be weighed in/out. Take scrapmetal to a merchant weighed in/out - no charge.
The DRW Iveco 3.5 tipper had a payload of 900 kg.
The 3.5 Luton back DRW has a payload of 1300 kg.
The 3.5 XLWB SRW not found out what that is yet.
2012 2.2 TDCi MK 7 E 5 100 HP - 350 3.5 tonne XLWB RWD H3 L4 Duratorq 2.2L CR TC 14 DSL 100/125 PS
Was DRRB 74 KW 100 HP 100 cv. Now CYR5 125 HP. PCM Siemens Continental fuel system.
OBD2 ELM 327 FTDI and Vlinker . Forscan 2.3.46
tranmx2
Postby mjsroofing » Sun Dec 07, 2025 12:39 pm
[quote="tranmx2"]Info' re' vehicle weights/payload etc is available on the net.
Transits are not the same. 2.6 2.8 3.5 DRW SRW which one do you refer to?
Mine a 300
Not sure what drw and srw means.
mjsroofing
Postby dumper » Sun Dec 07, 2025 12:50 pm
Single or double rear wheel
on google it gives 2000 kgs to 2300 kgs depending on model the only way to be sure is get it weighed
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby mjsroofing » Sun Dec 07, 2025 1:25 pm
dumper wrote:Single or double rear wheel
Mines fwd, so single axle single wheel
mjsroofing
Postby knobby1 » Sun Dec 07, 2025 8:37 pm
mjsroofing wrote:
tranmx2 wrote:Info' re' vehicle weights/payload etc is available on the net.
Mine a 300
DRW = Dual Rear Wheel...SRW = Single Rear Wheel.
If he had read the title, he would know is was a LWB, Medium roof FWD. Can't say I've seen any dual rear wheel FWD's about..! :roll:
Lord Knobrot (Smithy)
Postby andz327 » Mon Dec 08, 2025 2:30 am
Had same van only the previous owner had down graded it to a 280 for some strange reason and with towbar, 50kg of tools ,and 30kg trolly jack it was around 2200kg
andz327
Postby mjsroofing » Wed Dec 17, 2025 9:19 am
andz327 wrote:Had same van only the previous owner had down graded it to a 280 for some strange reason and with towbar, 50kg of tools ,and 30kg trolly jack it was around 2200kg
Thank you, good info, so with no towbar , empty about 2100 i guess.
mjsroofing
Postby andz327 » Wed Dec 17, 2025 12:30 pm
Think to be safe 2200kg cause mine might have been nearer the 2300kg , get it weighed at your local council tip, scrap metal yard etc
andz327
Postby dumper » Wed Dec 17, 2025 1:14 pm
Have you got a rolling road brake test print out from your last mot it should give you the axle weights add them together to give the van weight.
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby mjsroofing » Thu Jan 01, 2026 7:34 pm
dumper wrote:Have you got a rolling road brake test print out from your last mot it should give you the axle weights add them together to give the van weight.
Never thought of that, good idea., Thanks.
mjsroofing
Postby mjsroofing » Thu Jan 01, 2026 7:35 pm
Yeah ill get it weighed once it's back on road, in the process of welding it up again lol.
mjsroofing
