Hi hoping to get some extra pearls of wisdom here on my 12 plate tourneo
My engine started with a mild oil leak on the drive bit annoying but initially as the whole engine was covered at the front including the top of the rocker case, my methanic replaced the oil injector seals etc, after that the top half of the engine is free of oil, but as I still had small oil pools on the driveway I got him back to further investigate, he found oil bubbling at the air inlet manifold so he sent me to a garage in Derby that did a crankcase pressure test, they came back saying it was excessive and could be either a clogged/stuck PCV valve or a failing engine. The engine sounds spot on and has plenty of power at speed and has happily towed a twin axle caravan all summer (apart from a couple of moments up hill when it went into limp home mode).
So has anyone else had similar issues and positive outcomes?
My family heavily rely on this vehicle everyday so its going to be a big blow if its not economically fixable.
Other points to note,
1. I've had more than 1 turbo blow in the last 6 years however one was possibly diagnosed as a wearing guide rail on timing chain? as parts of this were apparently found when they replaced the timing chain 2 years ago.
2. While towing a heavy caravan up hill occasionally the engine has dropped into limp home mode but this only happens after at least an hour of towing.
3. i get puffs of smoke on start up not first thing but after a restart when engine is warm.
4. Not lost a drop of coolant in the 6 years we have had it.
5. Starts perfectly every time
would appreciate any help or advice thank you
