vansit1 wrote:i felt that +180 was really easy too, but i dont think that it is incorrect, because it is the spec and there is no way its gonna move anywhere. 1 of the bolts even got a bit bent during shipping, so i just straightened it out with my fingers lol
i might have had a bit of oil in the holes tho, because the old ones looked a bit black-oilish, so maybe stiff bolts have some junk in the bottom already?
rossco_pb wrote:Cheers Mark, finally got it going. Hopefully all done right enough lol
As for injector bolts have paint marked their tightened position and will monitor them over time
rossco_pb wrote:So if they come loose due to the copper washer squishing or injector hammering can you just tweak the bolts? Would assume so as they certainly are not under much strain at the point?
vansit1 wrote:i dont think 10.9 needs to stretch, so those are def the wrong ones. might be for mk8 only, espec when its m7 also?
