Part numbers for mk7 needed.
Postby riauba » Sun Dec 28, 2025 1:33 pm
Hello, guys. Have 2012 l2 h2 t350 fwd transit with euro 5 engine. Driveshaft seal on the drivers side started to leak and was looking for a new one, eurocarparts, or gsf they both giving me seal that has inner and outer diameter too small, and their systems doesn't list any bigger diameter seals. Also van had acvident and front shock was replaced, and i think it was replaced with absorber from swb low roof, because van on passengers side sitting lower than drivers side, and spring replacement didn't improve the thing, so i beloeve shocks are different lenghts? Ford dealer not an option for me at the moment. So asking you maybe anyone got access to ford parts catalogue and give me the right size seal and shock absorber numbers? Regnr.EF62AXS,or vinWF0XXXTTFXBP27252
riauba
Re: Part numbers for mk7 needed.
Postby gt_addict » Sun Dec 28, 2025 2:17 pm
Take a look at catcar.info. Use the drop down menus to select what van and variant you have and you should be able to get ford part numbers for whatever you need.
It can be a bit finicky at times and needs to be refreshed/reloaded.
gt_addict
Postby riauba » Tue Dec 30, 2025 12:24 am
gt_addict wrote:Take a look at catcar.info. Use the drop down menus to select what van and variant you have and you should be able to get ford part numbers for whatever you need.
Thanks, still got seal that is smaller diameter than current on my gearbox.
riauba
Postby andz327 » Tue Dec 30, 2025 12:32 am
What size do you require????
andz327
Postby knobby1 » Tue Dec 30, 2025 8:53 pm
riauba wrote:Thanks, still got seal that is smaller diameter than current on my gearbox.
The seals usually have their size written on them....just take it to a bearing/seal supply and they'll match it up.
Lord Knobrot (Smithy)
Postby riauba » Sat Jan 03, 2026 3:08 pm
Gave up for a while. But even transit ctalogue gives 1 only option with the too small size the inner size of seal they selling is ~40mm diameter, and my seals are around 50mm.
riauba
Postby knobby1 » Sat Jan 03, 2026 9:27 pm
riauba wrote:Gave up for a while. But even transit ctalogue gives 1 only option with the too small size the inner size of seal they selling is ~40mm diameter, and my seals are around 50mm.
Ford Pn: for the FWD 6 speed VMT6 is 1490305 (42.7mm x 60.3mm x 12mm)
The 5 speed VXT75 seal Pn: 1543933 (40mm x 55mm x 12mm) and is obviously different to the 6 speed.
Postby Byron222 » Wed Jan 07, 2026 8:33 am
For your Ford Transit MK7 FWD, the parts you need depend on the heavy-duty T350 chassis. Standard parts often fail because they are designed for lighter models. The correct driveshaft seal is Ford Part No. 1490305 (Engineering No. 8C1R-3K169-AA). Unlike the smaller seals found at common retailers, this version has a 40mm inner diameter and 55mm/62mm outer diameter. It is specific to the 6-speed VMT6 gearbox used in Euro 5 front-wheel-drive models. Regarding the shock absorbers, you are correct. The T350 L2H2 uses a heavy-duty strut (Ford Part No. 1769144). SWB low-roof models often use a shorter strut, which explains the uneven ride height. Ensure the new strut is rated for the 350 series to match the driver's side.
Byron222
Postby andz327 » Wed Jan 07, 2026 12:17 pm
Byron222 wrote:For your Ford Transit MK7 FWD, the parts you need depend on the heavy-duty T350 chassis. Standard parts often fail because they are designed for lighter models. The correct driveshaft seal is Ford Part No. 1490305 (Engineering No. 8C1R-3K169-AA). Unlike the smaller seals found at common retailers, this version has a 40mm inner diameter and 55mm/62mm outer diameter. It is specific to the 6-speed VMT6 gearbox used in Euro 5 front-wheel-drive models. Regarding the shock absorbers, you are correct. The T350 L2H2 uses a heavy-duty strut (Ford Part No. 1769144). SWB low-roof models often use a shorter strut, which explains the uneven ride height. Ensure the new strut is rated for the 350 series to match the driver's side.
was under the impression the longer strut only sat through the knuckle more but from knuckle to spring seat remained the same length??
andz327
