Bat135 wrote:Hi. I have a transit mk7 RWD.
It has the engine that runs fromt to back rather than left to right.
I have black smoke intermittently and grey smoke on startup. The intermittent black smoke occurs when revving high, under load or uphill.
I also have the following error codes on forscan. Mainly related to EGR valve. The problem is I changed the EGR valve not so long ago. Could it be the wiring loom that plugs into the EGR valve that’s causing this and not the EGR valve itself?
Pic below of the codes.
Would a removal and cleanup of the EGR valve and the intake solve this? Could I blank the EGR valve off as a possible solution too?
Any advice would be appreciated as it’s driving me nuts. Also noticed lower fuel economy. You might need to zoom in to see error codes.
Thanks in advance. Any insight would be appreciated.
Bat135 wrote:I didn’t reset pcm module. But only have the trial version. So not sure if I can do that.
Regardless of possible vacuum leaks from pipes and intake manifold, as lord knobrot suggested,it’s still showing EGR error codes. So might be two things going on at same time? Not sure.
The other issue is I fitted a cooled version of the EGR and my van is uncooled version. I didn’t join the exposed pipes with a piece of pipe as I have since found online might be needed. Not sure. In a loop kinda of thing do they are not exposed.
IT'S NOT VACUM LEAKS IT'S BLOWING NOT SUCKINGBat135 wrote:Ok
I will do the reset and che k fkr vacuum leaks. I will then get back to you with an update. To see if these either fix it or can be eliminated.
Thanks for your help so far.
Bat135 wrote:Think it was aftermarket EGR
Will cleaning the EG R and fitting new wiring connector be a good place to start? It’s like the EGR is not being recognised. The symptoms are 100pc loss of power up hills and smoke under load or on hills. Strangely enough it seems to have more power with EGR plugged in than without. But intermittent black smoke with it either plugged in or unplugged.
And error codes above.
Users browsing this forum: Google Adsense [Bot], musicfunkydude
