2.4l Duratorq TDdi MAP Sensor
Postby MK6CamperMan » Mon Feb 16, 2026 1:24 pm
I'm trying to locate the MAP sensor on my van, the manual states that on the early models that it can be mounted on the bulkhead or Intercooler. I have found what I think is the sensor mounted on the bulkhead at the rear of the engine compartment, can anybody confirm if the image below is of the MAP sensor before I remove it?
Cheers Andy
https://flic.kr/p/2rWUPYT
MK6CamperMan
Re: 2.4l Duratorq TDdi MAP Sensor
Postby knobby1 » Mon Feb 16, 2026 7:40 pm
MK6CamperMan wrote:I'm trying to locate the MAP sensor on my van, the manual states that on the early models that it can be mounted on the bulkhead or Intercooler. I have found what I think is the sensor mounted on the bulkhead at the rear of the engine compartment, can anybody confirm if the image below is of the MAP sensor before I remove it?
Cheers Andy
Does this help..??
https://www.catcar.info/ford/?lang=en&l ... IrMA%3D%3D
Lord Knobrot (Smithy)
Postby MK6CamperMan » Tue Feb 17, 2026 2:07 pm
Cheers Andy
Does this help..??
Yes it does, thanks, my one is the early one mounted on the bulkhead, just waiting on the replacement arriving.
Cheers Andy
MK6CamperMan
