metalworker0 wrote:Think you might have to do an EGR calibration/learn on forscan first, as you've installed a new EGR All the best.mark
Bat135 wrote:*** YOU WILL NEED TO CLICK ON EACH IMAGE AND ZOOM TO READ TEXT. ONE IS ERRIR CODES IN DTC. ONE IS SCREENSHOT OF FAILED INJECTOR PILOT LEARN AND AT WHAT POINT IT FAILED. AND ONE IS THE CYLINDER BALANCE FIGURES ***
Bat135 wrote:As interesting as this is. None of it solves the issue. Driving me nuts this damn van. Just can’t seem to get it running right and this is the last issue. Last error code.
Is there anyway of being able to complete this damn injector pilot learn. Tried it loads of different times and after different runs to get engine hot. Always fails at pressure point 5. Is there something wrong with the injectors? Is there anything I can try to rule stuff out with this learn failure. I only have the free version of forscan so it doesn’t allow me to see the injector learn numbers fkr each injector. Otherwise I could do it manually by driving in 3rd gear upto 3000 revs then let off till it goes back to 1500 rpm untill each injector has a value of 7. But it doesn’t have the PIDs for the individual injector learns in my free version. Don’t know if this changes with paid for version. So I can see when each number reaches 7.
Users browsing this forum: Google Adsense [Bot], shonkers
