Hi,
Appologies if there are posts on this topic already. Is the part number for the coolant hose, that sits above the start 6C1118C266AD. I just want to confirm before buying an incorrect hose. The engine has some oil leaks in this area. Given that the starter motor replacement fix is a mission, should I also take steps to fix some oil leaks while the starter motor is out. Are there any discussion posts on how to identify and fix engine oil leaks in this area. Heat from the engine and leaking oil are degrading the protective tubing of electrical wires, and I assume will also bake hard the wires themselves. In the attached photos, you may see where I have used garden hose to recover the wires, is this a bad idea, should I buy the correct protective tubing.
Any assistance will be gratefully appreciated.
Some photos and teh part image from the internet is attached to help explain the location on the vehicle.
