Mk7 2.2 2011bad starting
Postby tompe » Sun Mar 01, 2026 8:29 pm
Hi all after some help from u all as once again pulling my hair out right ive a mk7v2.2 2011 euro 4 transit in the last 18 months its had new injectors and deisal pump egr dmf clutch starter motor camshaft sensor crankshaft sensor the black box at the end of key barral heater plugs and still a bad starter can turn the key 10 times and wont start sometimes starter will wind on other times it will fire and the starter will cut straight off one it dose start it will go assoon as I turn the key .when it starts first time it will smoke a bit but clears fast any help would be great thanks inadvance
tompe
Re: Mk7 2.2 2011bad starting
Postby andz327 » Sun Mar 01, 2026 11:08 pm
what horse power?
how many miles has it done?
what codes are you getting?
possibly worn timing chain causing cam and crank not to sync
when you say starter winds on do you mean its not catching and not turning engine over and just spinning or its turning over but not starting ???
andz327
Postby trnx » Mon Mar 02, 2026 9:40 am
Fuel supply - poor electrical/tronic connection. Could be both.
E4
lots of posts re SCV PRV on HP pump. Posts re fuel filter, leak in fuel suction pipe.
Mk 7 E5 DPF RWD XLWB SRW
trnx
Postby DanMK7uk » Mon Mar 02, 2026 11:54 am
Good advice so far just to add, may be worth checking out earth points too.
As previously mentioned though get it plugged in and see what information you get to go off and let us know.
DanMK7uk
Postby tompe » Tue Mar 03, 2026 6:16 pm
andz327 wrote:what horse power?
P040 30 is the fault code 172457 miles .with starter it will fire but wont start and the starter will stop wont wind on other times when it fires the starter will wind on it the trend model so think its 180
tompe
Postby trnx » Thu Mar 05, 2026 7:42 am
P040 30 EGR info' on web.
trnx
Postby tompe » Sat Mar 07, 2026 7:48 am
trnx wrote:P040 30 EGR info' on web.
It's had a genuine ford egr on it
tompe
Postby knobby1 » Sat Mar 07, 2026 9:24 pm
EGR valve stuck open or closed won't stop the engine starting. They don't need glow plugs to start either...unless ambient temps are -5C or below.
When were the learns last done..?? Euro-4 pumps rarely fail.
Lord Knobrot (Smithy)
Postby tompe » Sun Mar 08, 2026 4:41 pm
The pump and injectors was change 3 years ago all genuine ford i brought the van 18 months ago as a none starting van took egr inlet manifold of and clean replaced egr heater plugs seemed to be ok then went to having to try 6/10 times for it to start changed starter motor still the same sometimes the starter wont wind on when it fires no start other times starter will wind on also change relays battery clean earth's there are no fault codes at all now put old camshaft sensor back in. When it dose start it smokes and smells like un burnt deisal .then rest of the day it will start as soon as u touch the key
tompe
Postby knobby1 » Sun Mar 08, 2026 9:20 pm
tompe wrote:The pump and injectors was change 3 years ago all genuine ford i brought the van 18 months ago as a none starting van took egr inlet manifold of and clean replaced egr heater plugs seemed to be ok then went to having to try 6/10 times for it to start changed starter motor still the same sometimes the starter wont wind on when it fires no start other times starter will wind on also change relays battery clean earth's there are no fault codes at all now put old camshaft sensor back in. When it dose start it smokes and smells like un burnt deisal .then rest of the day it will start as soon as u touch the key
Once again...when were the learns last done..??
Postby DanMK7uk » Sun Mar 08, 2026 9:25 pm
Have you 300 bar at cranking (to add to knobbys last post).
You need to get forscan software onto it and see what’s happening.
DanMK7uk
Postby metalworker0 » Sun Mar 08, 2026 9:27 pm
Previous post in 2025.. what pump are you talking about? .
Cleaned all earth straps still messing around ive noticed that the feul pump is getting very hot after engine is off while running seem ok but to hot to touch when off is this the a failing pump
all the best..mark
Postby tompe » Sun Mar 08, 2026 10:05 pm
I would say when it had pump and injectors I not heard about learns before so couldn't be 100 percent on that wot dose it entails
tompe
Postby DanMK7uk » Sun Mar 08, 2026 10:06 pm
metalworker0 wrote:Previous post in 2025.. what pump are you talking about? .
all the best..mark
Assume HP as euro 4 ?
DanMK7uk
Postby DanMK7uk » Sun Mar 08, 2026 10:08 pm
[/quote]I would say when it had pump and injectors I not heard about learns before so couldn't be 100 percent on that wot dose it entails[/quote]
Its a service procedure which is often overlooked ! Knobby will explain better than I, its often where we start if things are a miss with idle / running / starting issues.
DanMK7uk
