mk7 starting problems.
Postby Transit Paul » Tue Mar 03, 2026 1:53 pm
Hi peeps, I am having trouble starting a transit mk7, it does not crank over but if you take the battery lead off and put it back on again it starts first turn, however you cannot switch it off again unless you disconnect the battery, It gives the impression of what a stuck relay would do, any ideas of what I should be looking for would be a great help.
Transit Paul
Re: mk7 starting problems.
Postby metalworker0 » Tue Mar 03, 2026 5:12 pm
Normally when you post a good idea to put the details in fwd rwd year engine size
then i could have lead you strait to to the owners manual - where there are details of fuses and relays
as it is .. this is as near as i can get you to it
https://www.ford.co.uk/support/owner-manuals
Postby gt_addict » Tue Mar 03, 2026 5:27 pm
Have you checked for any codes since the problem started?
gt_addict
Postby Transit Paul » Tue Mar 03, 2026 6:36 pm
Sorry, but I am new on here and I need to settle in, it's a 115 T350 2.4 RWD. I haven't got a code reader so I would have to get it plugged in, however I do think that it's electrical & was wondering if anybody had come across this odd fault before.
Transit Paul
Postby metalworker0 » Tue Mar 03, 2026 7:50 pm
again no date given
so this is as close as it gets
https://www.ford.co.uk/support/vehicle/ ... er-manuals
find fuses and relays section
it will be the engine compartment fuse box// possibly relay R4 - starter enable
i say possibly because, I've just picked random manual and maybe not the correct date, don't want you willy nilly buying one .. test by substitution
also starter solenoid may be your second cause
Postby Transit Paul » Tue Mar 03, 2026 8:24 pm
Thanks for the info Mark. I will check out the fuses and relays as suggested, it's a 2009 that I have, sorry for missing that out
Transit Paul
Postby metalworker0 » Tue Mar 03, 2026 9:33 pm
If twin batteries, there also this big relay that swaps between them .. i'm not up to scratch on workings of that or how it would effect things, .. but others guys here will explain about it, it's, i think in the battery compartment or near it .. and it's the first fuse/relay box at the top of the list in the manual.
Postby trnx » Thu Mar 05, 2026 7:39 am
Transit Paul wrote:Hi peeps, I am having trouble starting a transit mk7, it does not crank over but if you take the battery lead off and put it back on again it starts first turn, however you cannot switch it off again unless you disconnect the battery, It gives the impression of what a stuck relay would do, any ideas of what I should be looking for would be a great help.
Put a new switch unit on the starter key - lots of posts re doing it.
Could be relay as you suggest.
Mk 7 E5 DPF RWD XLWB SRW
trnx
Postby Transit Paul » Sat Mar 07, 2026 11:10 am
Hi peeps, just a quick update for everyone, it was the ignition switch that was faulty, fitted a new ignition block and away it went, thanks for the help, regards Paul.
Transit Paul
