propshaft refitting question
Postby marc1234567 » Sun Mar 15, 2026 5:07 pm
2002 2.4 rwd chassi cab luton
i did make marks on both ends by the differential and the gearbox.
my 3 piece fits together with 2 keyed spline so the propshaft can only be put together one way.
but when it is refitted , is it possible that either the gearbox donut part or the diff end matters?
like i say i have marked anyway but was wondering just in case it had been put together incorrectly before somehow.
Previous mk 5 (2000) Luton body (2012-2013)
Mk 6 tddi 2.4 125ps RWD dropwell luton (2018 - present)
Mk 7 tdci 2.2 125ps RWD Luton / taillift (Aug 2021-present)
marc1234567
Re: propshaft refitting question
Postby Airthies » Sun Mar 15, 2026 5:50 pm
As long as all the UJs are in line the diff and gearbox ends don't matter.
Sent from my Pixel 8a using Tapatalk
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby marc1234567 » Sun Mar 15, 2026 5:53 pm
Airthies wrote:As long as all the UJs are in line the diff and gearbox ends don't matter.
Thanks again. Good to know. The fact the splines have a key means the pj's can only be one way.
marc1234567
Postby knobby1 » Sun Mar 15, 2026 7:57 pm
Have new uni joints been fitted..?? If so, it will need re-balancing, they can vibrate horribly if not balanced correctly.
Lord Knobrot (Smithy)
Postby marc1234567 » Sun Mar 15, 2026 8:27 pm
The part that attaches to diff had to be replaced.
marc1234567
Postby Airthies » Sun Mar 15, 2026 11:11 pm
I'm afraid, your lordship, I'd have to dispute the need for balancing after just replacing a UJ.
I've never had an issue with balance after replacing UJs or when shortening and making shafts for the 4x4 vans.
As long as they spin up full speed in the lathe without it walking across the workshop I count that as good
Local professional prop shop doesn't balance anything when they rebuild shafts.
Biggest cause of imbalance is incorrect reassembly.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Airthies » Sun Mar 15, 2026 11:15 pm
marc1234567 wrote:
knobby1 wrote:
marc1234567 wrote:[quote="Airthies"]As long as all the UJs are in line the diff and gearbox ends don't matter.
The part that attaches to diff had to be replaced.[/quote]You're lucky as the Mk7 & Mk8 props don't have master spline and the UJs are staked in place (rather than using circlips to hold the caps in) and heard of folk refusing to replace that type.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby andz327 » Wed Mar 18, 2026 2:48 am
Airthies wrote:
marc1234567 wrote:
knobby1 wrote:[quote="marc1234567"][quote="Airthies"]As long as all the UJs are in line the diff and gearbox ends don't matter.
Sent from my Pixel 8a using Tapatalk[/quote]had a rear uj to do on a certain mk7 2.2 jumbo transit about 7 months back , £18 for the new UJ , the van still driving with no vibration problems
andz327
