Cleaning inlet manifold.
Postby DanMK7uk » Tue Mar 24, 2026 9:12 pm
I plan to remove the inlet manifold, intercooler so on during the summer to clean etc.
Not something iv done before on these. (Mk7 euro 4) fwd.. whats the best way to clean and not get crap in the engine
Cheers
DanMK7uk
Re: Cleaning inlet manifold.
Postby metalworker0 » Tue Mar 24, 2026 9:20 pm
Walnut blasting
Bags are on ebay
So are cheap sandblast guns .. You don't need the full blown hoover outfit
Tape off the open ports that you are not blasting .. bring the one you are blasting up to tdc, so all valves are closed.. then away you go.
mask on , mess everywhere .. but the only other way is hand scraping with improvised tools or paying for a proper blaster
if you don;t have air at quantity 15 cfm. 150 litre tank or larger .. then you are screwed
Postby DanMK7uk » Tue Mar 24, 2026 9:27 pm
Il be in for some elbow grease then, Mark !
As long as the sun is shining I dont mind that !
My main worry was avoiding crap in the motor..
DanMK7uk
Postby knobby1 » Wed Mar 25, 2026 1:05 am
DanMK7uk wrote:Il be in for some elbow grease then, Mark !
Horrible messy job....with the inlet manifold, once removed you can hit it with oven cleaner and a good old fashioned garden hose, you may have to do this more than once. You may need to scrape out some of the heavily crudded areas. Make sure you wear gloves as the shite gets everywhere and gets into your skin.
Inside the ports on the head...just scrape out as much as you can get to with a suitable tool, (I use a modified long handle tea spoon)...again a messy job, but your engine will thank you. A good idea to replace the gaskets if they have not been done in the last 10 years. Just remember, at least one or two inlet valves will be open or partially open, so take care not to force too much down into the ports towards the valves.
Once it's all done, it might be a good idea to fit a catch can on the breather system..
Lord Knobrot (Smithy)
Postby DanMK7uk » Wed Mar 25, 2026 12:05 pm
Cheers smithy.. wonder if getting a new manifold might save alot of mess !
Il get a price. Might be worthwhile
Cheers mate
DanMK7uk
Postby metalworker0 » Wed Mar 25, 2026 3:34 pm
seems to be plastic .. i could offer dozens of suggestions on how to clean if alloy.
Postby DanMK7uk » Wed Mar 25, 2026 5:20 pm
metalworker0 wrote:seems to be plastic .. i could offer dozens of suggestions on how to clean if alloy.
Yes plastic on these.. gonna get a price if reasonable might save some hassle !
DanMK7uk
Postby gt_addict » Wed Mar 25, 2026 7:00 pm
I know yours is EU4 but my EU5 one was only £120 from Fords. New inlet gaskets included. Much easier than trying to manually clean it.
gt_addict
Postby knobby1 » Wed Mar 25, 2026 7:39 pm
DanMK7uk wrote:Cheers smithy.. wonder if getting a new manifold might save alot of mess !
Cheers mate
Yep...a good option if you can find them easily and cheap enough.
Postby DanMK7uk » Wed Mar 25, 2026 8:36 pm
gt_addict wrote:I know yours is EU4 but my EU5 one was only £120 from Fords. New inlet gaskets included. Much easier than trying to manually clean it.
Nice one
DanMK7uk
Postby ned » Wed Mar 25, 2026 9:17 pm
The crap is already getting in the engine, I used brake clean and tough wipes when I did mine on my mk6, very messy but well worth it, an oil catch can can cut down some of the crud in future
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby vansit1 » Sat Mar 28, 2026 9:46 pm
find a cordless drill and stick couple of zip ties at the working end
vansit1
