Mk6 2.0 tdci rough idling no codes
Postby trannyfreak » Sun May 03, 2026 11:45 am
Hi all, yesterday I was given a mk6 ford 2.0 tdci transit toureno, been stood a few years, non starter, managed to get it going but its idling bad engine shaking real bad, did have a code (p0100) which i cured that was air filter soaking wet and a chunk of it wrapped around the air mass sensor, but the idling i cant suss out, I cracked off the injectors 1 by 1, 1 2 and 3 cuts straight out, injector 4 when cracked off seems to make the van run a bit better but doesn't make the van cut straight out like the rest, any suggestions on this? Many thanks
trannyfreak
Re: Mk6 2.0 tdci rough idling no codes
Postby knobby1 » Sun May 03, 2026 9:45 pm
trannyfreak wrote:Hi all, yesterday I was given a mk6 ford 2.0 tdci transit toureno, been stood a few years, non starter, managed to get it going but its idling bad engine shaking real bad, did have a code (p0100) which i cured that was air filter soaking wet and a chunk of it wrapped around the air mass sensor, but the idling i cant suss out, I cracked off the injectors 1 by 1, 1 2 and 3 cuts straight out, injector 4 when cracked off seems to make the van run a bit better but doesn't make the van cut straight out like the rest, any suggestions on this? Many thanks
Pop the fuel filter off and cut it open, check for metalic sparkly bits...the Mk6 TDCi Delphi fuel systems are well known for being quite fragile and the pumps tend to eat themselves from the inside.
Lord Knobrot (Smithy)
Postby trannyfreak » Sun May 03, 2026 11:53 pm
Cheers mate I was hoping you commented :) is will check that out tomorrow many thanks
trannyfreak
Postby trannyfreak » Mon May 04, 2026 5:17 pm
Update.... no metallic fillings at all in the filter, many thanks
trannyfreak
Postby knobby1 » Mon May 04, 2026 8:03 pm
trannyfreak wrote:Update.... no metallic fillings at all in the filter, many thanks
Maybe just a poorly injector or two, bad fuel..??...Or the wiring to them is not well....wiring not been eaten by rodents has it..?? Common on vans that sit around for a while.
Postby trannyfreak » Tue May 05, 2026 9:09 am
Hi will have a check today... I got a red spanner light on.dash, would a bad injector not flash up a code then? Many thanks
trannyfreak
Postby trannyfreak » Tue May 05, 2026 10:41 am
This is what I tipped into a clean tub from.fuel filter wouod you say thats filings or not? Many thanks
trannyfreak
Postby knobby1 » Tue May 05, 2026 7:50 pm
trannyfreak wrote:This is what I tipped into a clean tub from.fuel filter wouod you say thats filings or not? Many thanks
Are the particles magnetic..??
Postby trannyfreak » Tue May 05, 2026 9:04 pm
Hi mate, I ran a magnetic through it and nothing stuck to the magnetic, some bits looks shiny I rubbed a bit on my finger but it feels like fine grit but there aint much in the tub from the filter, hope this help many tganks thanks
trannyfreak
Postby Stevelien » Wed May 06, 2026 9:37 am
I would disassemble all the injectors and see what you find inside. Clean them (flush them out) and then put them back. Start the engine briefly for 5-10 seconds without the 4 electric injector solenoid valve controls connected to prevent them from running dry after cleaning. Then connect the electric controls and see how it starts and runs. There are plenty of videos on YouTube about disassembling these 2.0tdci injectors. As mentioned, if you find a lot of metal particles, the pump is dead. Keep a close eye on the order of the individual injector parts before reassembly. There could also be water in your diesel after years of stagnation; it won't run well on that either.
Stevelien
Postby trannyfreak » Wed May 06, 2026 10:54 am
Cheers mate I will remove one today and strip it down and see what I find, just hope it aint the pump, and just dodgy injectors, many thanks
trannyfreak
Postby ned » Wed May 06, 2026 12:18 pm
Be careful taking the injectors apart theres little spring inside that usually fooks off somewhere, ask me how I know :lol: I might have some injectors in the shed somewhere, 4 remans from pf jones with about 5k on them and some good second hand ones that’s came out of a running van, I’ll have a look for them this weekend and work out a price if your interested.
When I had my mk666 tdci I chased a fuel issue for 7 year and never got to the bottom of it
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby trannyfreak » Wed May 06, 2026 2:40 pm
ned wrote:Be careful taking the injectors apart theres little spring inside that usually fooks off somewhere, ask me how I know :lol: I might have some injectors in the shed somewhere, 4 remans from pf jones with about 5k on them and some good second hand ones that’s came out of a running van, I’ll have a look for them this weekend and work out a price if your interested.
Ah ok, cheers for the info mate, yes please ill be interested along with a fuelpump haha, but will be interested in the injectors cheers mate
trannyfreak
Postby ned » Wed May 06, 2026 4:37 pm
I did buy a second hand fuel pump off a mondeo but never fitted it, I’ll have to see if I still have it or it got scrapped with the van, hopefully it’s in the shed or my mums garage, I’ll look for the injectors this weekend
ned
Postby trannyfreak » Wed May 06, 2026 7:30 pm
Cheers mate
trannyfreak
