I'm repairing a wire harness of rear right door. It has one plug in the door connected to the lock & two plugs (one gray & one black) connected behind a lamp in the rear right pillar.
Someone decided that this harness will have all wires black with no signatures on them. What a genius. A couple of wires were damaged, but still connected so I soldered a proper connection & insulated them. Two wires are still broken & I need to know which one is which before connecting them.
On the lock side my broken wires come to pins 8 & 5
On the connector that's inside the pillar my broken wires go to pins 3 & 5
I want to find someone who will check in their car to which pins on the lock side go to 3 & 5 from the pillar black plug.
