Alloy wheels query
Alloy wheels query
Postby trannyfreak » Wed May 27, 2026 7:29 pm
I got a get of 16" tourneo alloy wheels can i put these on a lwb 15 seater minibus the tyres are smaller then.mine but.if I put my tyres on can.i run them on. My mk6 lwb?
trannyfreak
Re: Alloy wheels query
Postby knobby1 » Wed May 27, 2026 7:59 pm
trannyfreak wrote:I got a get of 16" tourneo alloy wheels can i put these on a lwb 15 seater minibus the tyres are smaller then.mine but.if I put my tyres on can.i run them on. My mk6 lwb?
Is the Tourneo still 5x160 PCD..?? If so, make sure they're load rated for the minibus...the Tourneo is a fair bit lighter than a fully loaded 15 seater.
Lord Knobrot (Smithy)
Postby trannyfreak » Fri May 29, 2026 7:29 pm
So if I took the tyres off my van and put them.on.to.tge wheels woukd that be ok? Many thanks
trannyfreak
Postby knobby1 » Fri May 29, 2026 9:42 pm
trannyfreak wrote:So if I took the tyres off my van and put them.on.to.tge wheels woukd that be ok? Many thanks
Wheels need to be load rated too..!! But in general, they should be ok....best to check if going onto a minibus vehicle carrying up to 15 people.
Postby trannyfreak » Sat May 30, 2026 9:51 am
Ok mate thankyou
trannyfreak
Postby metalworker0 » Sat May 30, 2026 8:00 pm
Another thing to beware of .. sometimes the studs for steel wheels are too short for the alloys. they were on my connect. you end up with the nuts only holding them on with 4 threads!
Postby Altransit » Sat May 30, 2026 9:37 pm
metalworker0 wrote:Another thing to beware of .. sometimes the studs for steel wheels are too short for the alloys. they were on my connect. you end up with the nuts only holding them on with 4 threads!
Additionally, (whilst you're considering your options) you can't use your existing steel wheel nuts with alloy wheels, (alloys need a taper fit nut), and you cannot use the wheel nuts from Custom or Mk8 alloys on a Mk6, because the threads are different :)
