Today I started of as normal, my first call was only a mile down the road. I went to start when I had finnished there and though it turned over it didnt fire, I tried several times and even locked an unlocked the van incase it was imobiliser fault.
Luckily my mate who has his own garage was only a 5 min walk away so I popped into to see him and borrowed his scan tool.
It came up as a cam sensor fault, this has been replaced a few times as I keep getting this code but it doesnt usually stop it starting.
I wiggled the plug and turned the key and it started instantly and has done all day.
i can only presusme the plug for the cam sensor is not making the best of connetions.
Spoke to my local Ford dealer who is very helpful and had a look and reckons the plug or a repair kit for the plug is not available and it would need a new loom at £500 and some change.
Has anyone ever come across this before or found a way of repairing this plug.
I suppose I could go to the scrapyard but the chances are its not going to be in much better condition than mine.
Mine is a 200 ps but the part number for the sensor is the same for a 2.4 so I presume the plug is the same.
