Mk7 2.4 randomly is a nightmare to start just cranks but won’t fire
Starts perfect first thing in morning every time, rest of day after it’s been running it’s random if it starts or not, seems worse if try and start it soon after making a journey, sometimes trying about 5-6 times it will finally fire up, other times takes a lot more, sometimes just pulling the hose of the air filter box and trying with it off will start straight up not sure if that’s just coincidence as other times it does nothing
Once started it runs and drives perfect
Already changed ignition switch, fuel filter and housing, crank sensor, o rings on injectors not sure what to try next, the problem did get gradually worse at first it occasionally would fail to start first time but second time would fire straight up and gradually got harder and harder to start each time it did it
Thank you in advance
