Anothertransit12 wrote:Hi Lads. I got my hands on a low miles 2.2 2008 transit a few weeks back. Great little van as tight as the day it was made but the locking is annoying. The key fob mostly failed to open the doors when i got it first and i put it down to a failing battery in the key, However as time goes by it is getting slowly better and i now feel that it is not a low battery problem as after a long drive it can still fail to open the rear doors as soon as you get parked up when you would imagine the battery should be well charged even is it is was a poor battery. i now see that after a long drive if it fails to work and i restart the van again and run it even for a few seconds and then use the key buttons it will more often than not open the doors. there seems to be an auto lock system for the rear and side doors which does;nt help things. This was a one owner from new van which had a very easy life and i doubt the van was locked very often as it only ran around a small airport. given that it is slowly working a bit better i wondered part of the system just need some lube and that it may be starting to free up now in a problem area? it also sometimes fails to open the front doors using the key buttons which is really great as the key itself will never unlocks the door. When i am far from home and the button fails to open the front it takes a lot of swearing to get it to work. Also where on the van is the best place to point the key at? Has anyone got any suggestions? Thanks
Anothertransit12 wrote:one battery under the seat. Thanks very much for the help. It is great to know where the receiver is located. Would you have any idea why the drivers door never opens with the keys? I have 3 different keys and all of them lock it no problem but never open it.
Anothertransit12 wrote: Would you have any idea why the drivers door never opens with the keys? I have 3 different keys and all of them lock it no problem but never open it.
