After riding high since replacing all the calipers and hoses successfully, i went about bleeding the brake system since the old stuff looked like golden syrup!
Sadly though i messed up this relatively simple task, by letting the reservoir run below the MIN level!
I immediately felt it on the pedal go light followed by much swearing. Now i then went about re-bleeding the whole system and with the engine off the pedal is nice a firm, but as soon as i start the engine the first pump of the brakes the pedal drops to the floor but subsequent rapid pumps it firms back up (i feel i might be writing some erotic novel with this language!! LOL).
So can I simply continuing bleeding the system to fix this, or have i got air in the ABS module etc and need to do a FORSCSAN ABS bleed?
Any help is much appreciated.
Cheers
Nick
Its a MK7 2007 FWD LWB (Motorhome)
