Speed incorrect on speedometer
Postby Deanojones » Tue Jun 02, 2026 6:58 pm
2004 transit minibus now a camper
Issue i have is the speedo reading 70 when im doing 30mph any ideas what it could be or where to look first, the person i bought it off sent me this reply as i was told it could be the wrong diff…..
Hey mate great to hear from you and glad you’re enjoying the van.
Don’t buy a diff!
I remember it fairly well so apologies for the long winded answer as I’m not technical.
The speedo originally worked so it’s not a diff change or anything like that.
Not long after I purchased the van it would only fire up intermittently so I spoke to the guy I bought it from and he’d had issues with a fuel pump sensor before and a company called autotronics had fixed it.
So I sent it there and it didn’t resolve.
I then tested a different ecu and that didn’t fix it either
Finally I purchased a reconditioned fuel pump (about £900!) and used the reconditioned pump sensor and while it worked fine since then the speedo was out.
I then sent the pump, sensor and ecu back to autotronics and they were sh*t and as I’d already spent a fortune on the pump, the work to be done and a recon ecu thought I’d live with the speedo
Any help or advice to get this sorted please
Dean
Deanojones
Re: Speed incorrect on speedometer
Postby metalworker0 » Tue Jun 02, 2026 7:11 pm
if it does not have ABS ..I would suspect the hall sensor at the gearbox.
Postby knobby1 » Tue Jun 02, 2026 7:59 pm
metalworker0 wrote:if it does not have ABS ..I would suspect the hall sensor at the gearbox.
Mk6 doesn't work off the ABS sensors like a Mk7...even if it has ABS. Will be taken from gearbox sensor.
Lord Knobrot (Smithy).
Postby Deanojones » Tue Jun 02, 2026 8:41 pm
Thanks Mark, can you send link to purchase please, im willing to try anything… been to france did 1000 miles and its put 3000 on the clock
Deanojones
Postby metalworker0 » Tue Jun 02, 2026 9:00 pm
sorry cant do that too many choices of gearbox .. i don;t know what one youlve got
there you do :
1. first choice British or Turkish
2. Second choice in British .. is three gearboxes
3. and the Turkish one has three gearbox choices
There you go
You find it, since you have the info, that i don't
https://www.catcar.info/ford/?lang=en
Postby dumper » Tue Jun 02, 2026 10:27 pm
If it’s still got original gearbox and axle maybe Ford can identify it from the reg number or has it a part number on the sensor
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby Deanojones » Wed Jun 03, 2026 7:44 pm
Thanks, iv ordered one today so fingers crossed but i have my doubts, hope your right
Deanojones
Postby Deanojones » Wed Jun 03, 2026 7:45 pm
dumper wrote:If it’s still got original gearbox and axle maybe Ford can identify it from the reg number or has it a part number on the sensor
Went on a site and put my registration in and pointed me to the 1, just hope it works, il keep this thread updated if it does
Deanojones
Postby Frag » Wed Jun 03, 2026 9:48 pm
Needs the axle ratio and tyre size setting checking in the pcm.
These can be changed and the revs per mile,ids standard would do it but will likely do a full reflash if settings are changed.
Don’t know if forscan is capable
Frag
Ford Technician
Postby metalworker0 » Wed Jun 03, 2026 10:45 pm
Don't know about that, just looked at a speedometer on ebay and looks mechanical with drum type mile gauge .. he said his mileage gauge was going up at a faster rate as well, so linked to the gearing thtat drives the speedometer .. which i think is driven by an electric motor , powered by the hall sensor ?? , just guessing.
Postby Deanojones » Sat Jun 06, 2026 1:31 pm
metalworker0 wrote:sorry cant do that too many choices of gearbox .. i don;t know what one youlve got
there you do :
There you go
Iv changed the sensor today and still the same, any other suggestions please im willing to try anything to get the speedo reading correctly
Dean
Deanojones
Postby metalworker0 » Sat Jun 06, 2026 2:22 pm
well you could go the forscan route as frag suggested .. but i have sort of got a gut feeling there is nothing digital about the set up and it is analogue.
i put into google a question:
old style hall sensor in gearbox - clocks reading double speed
read this ... if link doesn't work .. put in: old style hall sensor in gearbox, clocks reading double speed
https://www.google.com/search?q=old+sty ... nt=gws-wiz
Postby Frag » Sat Jun 06, 2026 2:37 pm
Is the bus a rwd 5 speed ?
Not the tdci with 6 speed?
Or a 5 speed originally,with a 6 speed fitted ?
If it’s all the same drivetrain as it left factory
The PCM is going to be the issue,it’s either got the wrong software completely,or the axle ratio / tyre size setting configuration is wrong for that vehicle
You need someone who knows what they are doing with a laptop.
If it was a 5 speed from factory,and someone’s converted it to 6 speed you may have same issue.
Frag
Ford Technician
Postby Deanojones » Sat Jun 06, 2026 2:49 pm
metalworker0 wrote:well you could go the forscan route as frag suggested .. but i have sort of got a gut feeling there is nothing digital about the set up and it is analogue.
Yes its analogue mark
Deanojones
Postby Deanojones » Sat Jun 06, 2026 2:51 pm
Frag wrote:Is the bus a rwd 5 speed ?
5 speed rwd all same as left factory, as stated in original post that I put a snippet from previous owner he changed fuel pump and had ecu sent off
Deanojones
